Integrated fridge warm
  • #87904
    char14lew
    I have a Hotpoint HS2322L that’s gone warm.The temperature control was flashing and beeping.As the temp is controlled electronically,i’m suspecting it’s the board.I changed the relay on the board as it wasn’t clicking when energized manually.This has cured the alarm flashing and beeping but fridge is still warm.The compressor is cutting in as normal and sounds fine. Can it be anything other than the board before i order a new one?
    thanks
    #436362
    char14lew
    Re: Integrated fridge warm
    it turned out this fridge had lost its gas!
