integrated washer dryer dead
Home Forums Public Support Forums Buying Advice integrated washer dryer dead
  • #72962
    kash1982
    Hi all
    Kash from Southampton hear after a bit of advice. I have looked through the buying guides and am still a bit stuck. I have a integrated zanussi washer dryer and the main board has given up. I’ve decided that cost of the repair plus the age of the machine I would just buy a new one. So basically I’m after a bit of advice of what integrated washing machine I could get for under £500?
    How many people are using the machine? Two adults one child one toddler and one baby
    How many loads of washing per day are you doing roughly? One- two everyday
    Do you line dry or use a tumble dryer? Line dry now
    Do you have size limits to what you can fit? Integrated
    Have you any special needs? Nope
    What sort of budget you have. Under £500.
    I’m not going to bother with a washer dryer as I’ve had enough repairing my own every year.
    Any help would be gratefull
    Kash
    #386093
    madangler1
    Re: integrated washer dryer dead
    Do your self a favour and consider do you really need a built in machine.
    Your paying way over the odds for that privilege alone.
    #386094
    DrDill
    Get your self a bosch built in machine, its a bit more than your budget but worth it, you will need to have the cabinet door redrilled so get a professional to install it who should have a hinge jig to do this.
    If as suggested you get a freestanding machine you will need to cut the plinth as this will look unsightly and the machine will stick out as the depth is greater
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #386095
    kash1982
    Ok some sound advise can anyone recommend any models. Something that is easy to work on and parts will be available down the line?
    #386096
    DrDill
    Bosch only do 2 models of built in, a 1400 spin 7kg load, and a 1200 spin 7kg load,
    Sent from my iPhone
