Integrated Washer trouble
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Integrated Washer trouble
  • #18203
    Deancowell
    Hi – Hoping someone can assist.
    Have an integrated washer -brand unknown. Stopped mid cycle – didn’t drain all of the water but some of it.
    Checked:
    Fuse
    Plug
    Drainage pipe for kinks – and have emptied the remaining water by disconnecting the hose.
    Cleaned out filter
    Have taken off the top and looked for an loose wires.
    Washer is fairly new – hasn’t played up before.
    When swithed on – the ‘on’ light is lit up – I know there is power coming through (managed a small shock so sure this is the case without a meter!) and turning the dial to different cycles has no affect – no water starts to fill – nothing at all.
    Is there anything else I can check before having to call in a service man to look at it. I’ve also checked the switchboard to see if anything had tripped – and all is ok
    Help! I’ve got no clean clothes!!
    Cheers
    #178115
    Hi Dean,
    We’ll need a make and model at thevery least to help. Try searching about on the kickplate or the actual machine door to give us a clue.
    Deancowell
    Re: Integrated Washer trouble
    Hi – thanks for the response.
    I’ve tried all over to see a make or model name – and ca’t actually believe that there is not one – but there isn’t any branding on this unit at all.
    We moved into this house and the kitchen looks like it was done recently – the other unit – dishwasher is a Diplomat.
    I found a barcoded serial number on the side of the unit –
    2000 44 11 060 014 103 003
    With an S1/2000 4330 number beneath it – but didn’t think this could be of use?
    Any advice?
    #178117
    Dave_Conway
    It’s also a Diplomat made br Merloni (Servis).
    It may be the drain pump which is here:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=162
    Power off when any cover removed please :zap: as you’ve discovered.
    If you’re unsure on checking further or fitting, check the repairs@ link below for an engineer 🙂
    #178118
    Deancowell
    Thanks Dave –
    As the machine doesn’t do anything now when I move the dial -Not too sure on how I would check this and guess its time to call in an engineer –
    Any ideas from anyone on what you can expect to pay for a call out – labour etc?
    Appreciate the help – was hoping the problem was a minor one.
    #178119
    Dave_Conway
    Labour varies quite a bit across the UK to be honest, best discussed locally with the repairer 🙂
