Dont know if anybody can help or not but today I had a look at a fully integrated indesit dishwasher DI62. The fault it has is as soon as the power is on and the door is closed all that happens is the first led for programme 1 flashes and the drain pump works.
I’ve checked all the usual, leaks in the base, anti flood microswitch sticking, pressure switch etc and everything is reading fine. The only solution I can come up with is that the PCB is faulty.
Has anybody out there had this problem?
Cheers
Nick
