I have a Zanussi DE 6854 (PNC 9119 15012/01) which, although around 10 years old, still works perfectly EXCEPT THAT sometimes, whatever the programme chosen, it does not heat, either in the ‘wash’ or ‘dry’ parts of the cycle. There are no flashing lights but only cold water is used and the contents are wet, but clean, when the door is opened. I suspect that the electronic progrmmer may be faulty. What else might be causing this problem and is it worth fixing?
Re: Intermittent heating fault on Zanussi dishwasher
Thank you ladom. Does the PCB slot-in or what? Is replacing it something I might do myself as a user with a modicum of common sense or would I need to call in an engineer?
