hi all,
the freezer seal has gone on my Hotpoint Iced Diamond freezer and I’m struggling to identify the model even after a couple of hours of googling images (label cleverly placed on the inside of the freezer is no longer legible). It’s a tall freezer, 135cm tall, 203 litre gross capacity/175 litre net capacity. Freezer seal dimensions (outside measurements) are 1259mm x 539mm. Picture below. Can any eagle-eyed Hotpoint specialist confirm which model it is ? I thought it may be an RZ84N but this is a guess only based on the dimensions.
Also, looking at the seal itself, there doesn’t seem to be an easy or obvious way to replace it easily – it doesn’t lift off easily, no screws to remove the inner cover on the door, & it looks like it is glued down with a plastic strip (that looks broken) covering it. Again, any advice please on how to do this? Is it a superglue job ? The seal replacement only needs to last a few months, since we are due to get a nw kitchen fitted by the end of the year anyway……
thanks
DS
