Is it ok to wire a plug on a 3kw cooker?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Is it ok to wire a plug on a 3kw cooker?
  • #77372
    kpmatthews
    I’ve searched for the answer and seen contradictory responses.
    We have a second hand smeg suk61mfx dual fuel with single oven. It has h05rr-f cable on the back which looks pretty meaty for a standard plug.
    Label on the utensil tray indicates 3kw.
    We have a separate circuit for the oven with plug socket behind the cooker and red isolation switch on the wall.
    Can I plug, or should I swap socket for a connection box?
    Thanks, Kris
    Mod edit: added your image via the attachment mode which much easier to see 🙂
    #402002
    Re: Is it ok to wire a plug on a 3kw cooker?
    If you read the user manual (download a copy from HERE ) It states you should use this flex….
