Is this a configuration problem ?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Is this a configuration problem ?
  • #72554
    oscar123
    I have just fit a new module to a Zanussi ZWD1470W but as soon switched on the rinse light flashes.. not sure if it is a configuration issue or dodgy board, it does not say on the sight if it is configuered or not 🙁 it was supplied by Connect by the way and there is no mediator available for this model.
    Oscar
    #384879
    repman
    Re: Is this a configuration problem ?
    922CB02A1507F9CF IS THE CONFIG CODE
    MODULE,NO 132 12 25-63/1 IS NOT CONFIGURED
    #384880
    oscar123
    Thanks for your quick reply repman.. now I just need to know how to put the code in :)not had to do one before. I have other service manuals down loaded I will check through. thanks again.
    Oscar
    #384881
    Criscold
    You have mail
    #384882
    oscar123
    Thanks to you both. very hepful indeed.
    Oscar
