is this board available to buy?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum is this board available to buy?
  • #67743
    john_d
    the board is from a hoover ppw166 washer/dryer
    #368340
    Re: is this board available to buy?
    Yes.
    if you supply the FULL serial number its available pre programmed.
    Bryan
    #368341
    john_d
    any idea how much, guess around the £100 mark?
    #368342
    Thats what we need for the price
    #368343
    john_d
    the ful serial no. of the machine or board, where do i find either?
    this any use?
    #368344
    Might have been better to keep it to your Original thread 😉
    Bear in mind that this part would come to you with no gaurantee and if you fit it without finding out why it blew in the first place then you will almost certainly blow a new one as well.
    #368345
    john_d
    iadom wrote:Might have been better to keep it to your Original thread 😉
    i was going to add it to the original but it seems to have died a death 🙁
    im no further forward to finding out what caused it to go so im resigned to the fact it is likely to go.
    #368346
    I wish I had a £100+ that I could afford to knowingly throw away. :rolls:
    You need to try and follow the tracks on the board to the nearby edge connectors and try and trace them to individual components. Water leaking onto the drain pump is a very common cause of failure on these machines. Leaks from the detergent to main drum inlet hose etc. Sometimes the small connector plug to the drain pump shorts across inside, not always obvious at first glance.
    I would say that if you do not identify the cause then there is a 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance the PCB will blow as soon as you switch the machine on. 😥
