Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Is this WMA bearing kit genuine?
- This topic has 6 replies, 4 voices, and was last updated 15 years, 1 month ago by
leavemetogetonwithit.
March 11, 2011 at 1:04 pm #61623
ParticipantGot a WMA 35mm kit off ebay. Paid a little more (still less than Connect though) because I wanted genuine and this was so described.
Looks just fine but not done many so not sure as it’s in odd packaging. Box with label which says, “WA-1000”.
Seal has embossed in rubber, “NWB-1068”. Bearings are rubber sealed and NWB again.
Can anyone confirm? Going to use it anyway, as no time to get another but want to know whether to favour the seller with future business.
Mike.March 11, 2011 at 10:01 pm #346971iadom
ModeratorRe: Is this WMA bearing kit genuine?
If it was genuine it would be in a white box with a Hotpoint/Indesit label on it and correct part number with bar code.
Can’t confirm those numbers as the only kit I have ATM is a Qualtex pattern one, I did order a gen one but was sent this one instead. :rolls:
March 12, 2011 at 12:13 am #346972leavemetogetonwithit
ParticipantRe: Is this WMA bearing kit genuine?
Pretty much as I thought. It’ll do the job I’m sure but I won’t be recommending the seller, unless it turns out the same markings are to be found on genuine kit. We all know how important a good seal is. Last genuine kit I had was in a plastic bag rather than a box though.
Mike.March 12, 2011 at 11:17 am #346973Martin
leavemetogetonwithit wrote:Last genuine kit I had was in a plastic bag rather than a box though.
Yeah, they come in plastic bags these days. Jim most likely uses the pattern ones which are every bit the same but a few quid cheaper for sure. Qualtex (BKT81) come out @ £9.60 (incl. Vodka & Tonic) and identical to the genuine in every way!:D
Cheapest of Fleabay by the way is £11.40
March 12, 2011 at 11:58 am #346974iadom
The Qualtex BKT81 I have in my hand does not have rubber sealed bearings which the genuine one does. The kit that Mike has would appear to be superior to the BKT81 I have.
I normally only use the gen ones, these were sent to me without asking after I ordered genuine.
Bag or box it should still have a proper Hotpoint/Indesit label on it.
March 15, 2011 at 10:19 pm #346975leavemetogetonwithit
Turned out to be a 30mm machine. First one I’ve come across. So I’ve had to order a different kit. Still curious about which makes and markings are on genuine bearings.
But hey! Look the site has suddenly gone super fast!
Mike.March 17, 2011 at 7:53 pm #346976gandh1
is it possible they are sourcing oem spec bearings, but not with the hp packaging as its cutting out hp mark up???
much like how connect do with some of the electruepart kit?
