is this worse job ever
  • #48609
    adv
    wat a mare tryin to fit door seal to this washer dryer.wjs1397w gave up after 2 hrs to try getin on ,are ther any tips to changin it goin back moro. or mitr just sell him new machine. wat a joke of a job 😳
    #297127
    keithwilliams
    Re: is this worse job ever
    yes it’s a pig.
    what i do once i’ve got the seal on the tub i wedge the spring in place at the bottom with my socket set extention bar and kind of hold it with my leg while chasing the spring round and round the seal. i think quickest i’ve done it 15 mins. a mate of mine holds the spring gently with long nose mole grips.
    #297128
    adv
    ha ur jokin this is a washer dryer tho. its tryin to get on vennt for dyer bit joke
    #297129
    bzz67
    we are lucky enough to have extra staff, four hands make it easy work 🙂 usually take the door off first.
    #297130
    adv
    mmmmmm 😆
    #297131
    rogue_element
    Hi adv
    esay job,
    1) unplug
    2) remove top
    3) remove dryer duckett ( f/setion x1, 7mm screw )
    4) remove door seal from cab edge
    5) long nose pliers and remove clamp thats holds ductet on to seal.
    6) pull off recir hose (do not undo clip)
    7) remove rest of seal
    8) refit seal on to tub and fit spring
    9) this is the bit the took me 2 hrs do do, till i worked it out
    refit duct on to seal, slide clap around ducket
    twist clip to gether THEN with a small straight egde screw driver inset and twist towards you ( it will not clip to gether) then twist and turn with long nose pliers.
    10)get some washy up liquid and smear around plastic nozzle and push in to seal 1ST refitting meatl holding clip
    11) refit ducket and leak test.
    with pratcie i had this all done in no more then 20 mins
    hope this helps
    rogue
    #297132
    adv
    cheers 😳
    #297133
    rogue_element
    no worrys m8
    let us know how you get on
    #297134
    boselecta
    Hi adv,
    Sounds like you are trying to do the job with the front dry duct still in place, take off the 7mm earth screw on top of the dryer and the other one in the facia and pull the front dry duct inside the drum.
    As soon as you have the front dry duct off its easy.
    #297135
    helo_75
    in the fascia? isnt it inside the door?
    #297136
    adv
    o rite didnt hink u can do that its al coverd in that silver insulating stuff, so u pull the nosel funnel bit into drum yeh?
    #297137
    helo_75
    no, take it out the top.. 2 bolts.. shimples
    #297138
    boselecta
    helo_75 wrote:in the fascia? isnt it inside the door?
    by the facia I meant the 7mm screw through the cabinet inside the door aperture
