is70c help please
  • #45716
    steve01246
    ive got an indesit is70c condenser dryer and it will run for approx 1 minute before it trips the thermostat and the electric.the dryer will run pefect while theres no heat i must have reset the thermostat now 20 times 😡 ive replaced the capacitor with new one.but this as made no difference.could it be the thermostat at fault? the cooling fan under the heater elements is ok any ideas would be very gratefully appreciated as i am now mind boggled as to what it could be
    #286741
    helo_75
    just put a heater on it
    #286742
    steve01246
    is70c help please
    helo_75 wrote:just put a heater on it
    hi helo_75 thanks for the advice ive looked at the heater elements and they look ok and before it trips out the backplate does get hot its as if it is overheating.i dont mind buying an heater for it as long as it cures the fault.another thing to mention is where the thermostats are was wet is this because the thermostat as tripped or is this a fault?once again thanks for your help
    #286743
    spimps
    Re: is70c help please
    Whilst it may “look” physically OK doesn’t by any means sonfirm it is.
    Presume the dryer will run without tripping the electrics when heater is not engaged.If it’s when it is reset that it trips you need a heater.
    The inner insulation in the heater has probably broken down in one area of it causing a hot spot which willprobabl overheat causing the safety stat to cut out at the same time as increasing the voltage leaking to earth which will take out your RCD.
    While your at it clean the fan baldes and the condenser likely they are choked with old fluff etc.
    BG
    #286744
    steve01246
    spimps wrote:Whilst it may “look” physically OK doesn’t by any means sonfirm it is.
    BG
    hi ive just spoke with a friend of mine and he as just explained everything as you have well done and thanks for your help i’m now not worried about buying a new heater and thinking it would make no difference.i love this forum without it i would be spending a fortune to make things work.
    thanks once again
    cheers
    steve
    #286745
    helo_75
    sorry if my previous post was a little abrupt
    i apologise, i was in a rush…
    however, i must point out that the fact that the heater was indeed wet, and that needs investigating
    theres probably a blockage in th e cahannel from the condenser chamber to the pump, leading to water overspilling onto the fan and wetting the heater
    the drain hole is situated in the pump chamber, and is on the bottom left of the the housing, under the pump… its worth pushing something through it to make sure its clear
    good luck
    #286746
    steve01246
    is70c help please
    helo_75 wrote:sorry if my previous post was a little abrupt
    good luck
    no problem i’m just glad of your help i have checked the drain hole and thats ok i think whats causing it to get wet is the steam off the clothes as it gets hot for the first minute then trips out
    thanks again steve
    #286747
    As cold, wet washing goes into your dryer then there would be no steam for quite some time.
    As helo_75 says, its caused by water being thrown onto the element by the fan.
    You may need to remove the condensor, lie down on the floor and reach right back into the condensor chamber, feel around in the channel at the back and pull out any fluff or gunge you find in there as well as poking a large plastic bag tie or similar through the drain hole from the water chamber at the back.
    The later elements have some slight modifications to help with this problem.
    steve01246
    iadom wrote:As cold, wet washing goes into your dryer then there would be no steam for quite some time.
    hi jim thanks for the info i will try this tomorrow you could be right (i hope you are 😆 )i will let every 1 know of the outcome
    thanks again
    cheers
    steve
    #286749
    You also need to keep the condensor clean, a real pain to do on these models but it should be done on a very regular basis, if you have one a blast through with a pressure washer or hosepipe in the back garden is the best way to clean them.
