ISE 10 1606W
  • #87435
    char14lew
    Anyone have knowledge on this machine.I’m trying to help a customer that’s been left stranded by ISE.It just wants to pump out.The thermistor has been changed.I’ve had this on Hotpoints and it’s always been the pcb.With no back up or spares, if any take an absolute age to arrive is there any point trying to save it!
    thanks
    #434829
    Re: ISE 10 1606W
    not seen many ise’s so don’t know this machine
    but
    when u say it just pumps out do you mean the pump wont stop or it will just drain nothing else
    if you can set a wash programme what happens ?
    dave
    #434830
    Re: ISE 10 1606W
    Overflow protection activated.
    If the machine thinks it’s full of water, all it’ll do is pump out on an emergency drain function. Could be something stuck on the pressure switch hose, could be the overfill pressure switch, the big mechanical one.
    char14lew
    Re: ISE 10 1606W
    thanks Dave and Ken.It won’t let a programme be selected.It’s stuck on one programme and pumps for a minute or two then stops.Then after a minute it starts pumping again.I checked the pressure vessel and took pipe off and blew gently and switch clicks.
    thanks
    #434832
    Re: ISE 10 1606W
    Did you reset the board?
    char14lew
    Re: ISE 10 1606W
    yeah tried that.
    thanks
