ISE 10 1607 Door Lock Change
Home Forums Manufacturer/WP/Insurer Specific Forums ISE Trade Support Forum ISE 10 1607 Door Lock Change
  • #59531
    Jonah
    Hi Guys, I’ve tried searching but no luck, have any of you changed a door lock yet as I have only adjusted them so far and I now have one that needs to be changed, any tips would be appreciated as looks like the front panel has to come off, any help appreciated 😀
    #338564
    Re: ISE 10 1607 Door Lock Change
    a 1607 with door lock issues? whats up with it?
    #338565
    Jonah
    Hi Mark,
    I’ve tried adjusting it a couple of times, used vaseline and silicone spray but it so hard to push the door into it to get it to lock the lady can’t do it as she isn’t strong enough so changing the lock might make it easier for her, there doesn’t seem to be an issue with the door
    #338566
    It won’t help Dave, it’d just be the same.
    Jonah
    Thanks Ken, probably thought so but I have to try it just to keep the customer quiet, you know what they are like, any how is it a nightmare job or not too bad?
    #338568
    No idea Dave as there’s never been one done yet!
    TBH though I doubt it’ll keep the customer quiet, if she’s not happy with it I doubt she’ll ever be. 😕
    Jonah
    I know mate, I always get them down here they moan for England, will let you know how I get on 😕
    #338570
    I would take a guess its not too much different from the old model, 2 screws under the front edge (may have to tip back machine to access) maybe a screw under the dispenser? Once the front panel is off, the cover around the door is probably spring clipped in place.
    Let us know.
    #338571
    Bill
    Before I retired I found the same problem was solved by undoing the screw that holds the emergency door open handle down by the pump filter works.
    Bill Ellis :scot:
    #338572
    Jonah
    Sorry lads but it’s a 1606, my fault typed it wrong as in rush, it’s the original model not the new one 😳
    #338573
    doh! easy job for you then.
