ise 10 a screw loose / or more
Home Forums Manufacturer/WP/Insurer Specific Forums ISE Trade Support Forum ise 10 a screw loose / or more
  • #51503
    delta01
    the leaking from door turned out to be down to the four screws that hold the door glas and seal in place had either never been tightened up / or had worked loose , when i separated the door outer the glass and retaining plates fell out , having never disembled the same i didf not realise at first what was wrong ,however on putting it all back together there was no more leak ……. so if you get a leak from door i suggest try tightening the four screws on the door
    i assume i can claim a call for this how do i proceed
    thanks john
    #308320
    Hi John,
    Yes you can and good catch.
    Just email in and ask for a job sheet for it.
