ISE 10 auto door release
  • #64439
    Lawrence
    Am I right in thinking that there is a way to switch off the auto door release on the original 10 ?
    If so how do you reset it to auto release ?
    Lawrence
    #357095
    nigegt
    Re: ISE 10 auto door release
    It’s under the child safty bit in the destruction book.
    1. Turn off the machine using the main power
    switch.
    2. Press the Door Open button while simultaneously
    pressing the main power switch.
    Release the buttons.
    3. Press the Key button and the red field goes
    out. Automatic door opening is now deactivated.
    4. Press the Start/Stop button to store the
    setting.
    If you want to reactivate the function, follow
    the instructions above. When you press the
    button with the key symbol (point 3), the red
    fields light up. Store the setting by pressing
    the Start/stop button.
    Nige
    #357096
    Lawrence
    Cheers Nige
