ISE 10 F3 check this!
Viewing 15 posts - 1 through 15 (of 25 total)
  • #55744
    Martin114
    Well Ive had a very pleasant phone call from a customer to say how pleased they are with their ISE10 washing machine.
    This was the very same customer who a week or so previous was demanding a refund citing the machine was ‘not fit for purpose’ :rolls:
    The Machine had a new pump due to being noisy with vibration problems, but also had an on-going problem with F3 errors which even after the new pump, were still there (if not even worse than before!).
    All the usual checks were made (coin in hose – eco ball sticking etc…) and the customer was advised to change detergent and reduce quantity.
    The result was poor was results due to very little detergent and still F3 errors, and a very unhappy customer. 👿
    Pondering on my next move I just happened to find an old Asko service bulletin (No. 171) identifying the same symptoms that this machine was exhibiting, which pointed to the filter insert not quite reaching the back of the filter housing, which in turn was making water recirculate inside the pump impeller chamber instead of going up the outlet hose.
    There would also not be enough flow to draw the eco ball down from its blocking position.
    As stated in the bulletin the cure for the problem is to fit an ‘o’ ring into the filter end slot . This extends the pump insert by 0.5mm and in fact closes the gap.
    The result has been dramatic, and I have fitted these rings on 3 machines now with equally dramatic results!.
    Anyway my customer has been able to return to her original detergent and is now able to use higher quantities without any problems and her rinsing/spinning results are great.
    I am now fitting these rings on all new installations and any service calls I make.
    Hope this helps some of you with similar problems.
    For reference:
    Asko o ring part number: 8901773
    I use item number BS216N70 from polymax.co.uk (about 10p each)
    Pdf bulletin
    Martin.
    #324994
    timdowning
    Re: ISE 10 F3 check this!
    Excellent info.
    That bulletin is from 2000 so why would the ISE10 be fitted without the ‘o’ ring?
    Remedy 2 is to change the pump complete so you would imagine this means all new pumps / machines after 2000 should have the ‘o’ ring fitted?
    Well done!
    #324995
    Martin114
    The later pumps were supposed to seal properly without needing the o ring mod, but it would seem that a lot of them would still benefit from it.
    The problem i had was a machine that had a brand new pump fitted!
    #324996
    kladave
    Thanks for this Martin
    Iv’e had the same on going problem and i just assumed it was over dosing on detergent.
    never had the problem in all the years dealing with ASKO…….
    #324998
    kladave wrote:Thanks for this Martin
    Did you try the ‘O’ ring tip Dave, I have one that is giving me the same grief. 😥
    kladave
    No Jim
    I looked at the website that Martin gave but I could not get an order up to and over their minimum charge.
    Pdf bulletin
    Martin.
    Just had a look at the polymax site but cannot find BS216 N70 ‘o’ rings?
    I don’t suppose you have a spare one you could post me until I manage to get hold of some.
    kladave wrote:No Jim
    So how did you resolve your F03 problem?
    I have found that a filter seal from a BEKO pump will fit into the rear end of the ASKO/ISE pump filter, not sure if that will have the same effect. 😕
    Martin114
    Just had another look on the polymax site and they are HERE
    If you want me to post you one, then let me know your address.
    Martin.
    #325003
    Ahh, I was just looking at the initial list. 😳
    I would be most grateful if you could stick me one in the post, I will PM you my address.
    I will get some ordered and let you have one back ASAP.
    Thanks.
    Martin114
    No problem Jim – be in the post tomorrow morning.
    #325005
    8)
    #325006
    Just a thought on this one, as Mark has probably seen more ASKO machines than most of us and yet not encountered this problem I wonder what the water is like in each of your areas?
    The water is very soft round here and I’m guessing it could by well on the hard side in Mark’s area.
    PS. I see you are in Burton upon Trent Martin, nowt wrong with the water round there eh. :beer:
    #325007
    Martin114
    :innocent:
