ise 10 Leak
  • #67010
    Steven
    I have been looking for the thread on leaking?
    Cant find anything but i am sure i read somewhere about these leaking from somewhere?
    been out to one that has been leaking for what appears to be a while as base is rusted?
    The thermistor was sat in water in the craddle!
    Any ideas cant see where its coming from?
    Steven
    #365972
    Re: ise 10 Leak
    Overdosing and foaming up in the drawer, forces out the dispenser hose.
    That’s the favourite in the hotels etc. :rolls:
    timdowning
    Steven
    Re: ise 10 Leak
    Thanks Tim, Had a read and similar to jonnyhoz fault!
    But had a good look around and no trace of leaks at all no obvious water marks which if it was soapy you should see!
    my guy went there before and replaced thermister the cradle was dry!
    This time as the fault has re appeared with exact same symptoms, so found it now wet, so suspect that it dried out before we got there previously!
    He took several photos although does not help, it does show that it has been leaking for some time, rust spots in the base, motor has traces of rust patches all over so definatly a leak coming from higher up!
    Dried out thermiser which is why the board was going loopy and prevented it being reset etc.
    Still not working properly?
    He checked the dispenser hose and removed it, it was all bone dry, no signs of any dampness!!
    Will have to take longer more thorough look or just seal up dispenser?
    Steven
