ISE 10 noise on spin
  • #42884
    EFS
    My ISE 10 developed a knocking noise on spin which gradually got worse over some weeks.
    I tracked it down to the drum pulley moving on its splines.
    I removed and refitted the pulley and all seems well but the question I have is should I fit a new pulley?
    The fit on the splines is not tight at all and the spring washer behind the pulley pushed the pulley off the shaft when I removed the bolt.
    Is it meant to be like this?
    Steve
    #275254
    Re: ISE 10 noise on spin
    Dunno TBH Steve I’ve never had to take one off except during factory training in Sweden nearly 18 months ago and I can’t recall now.
    I’ve certainly not seen or had a problem in that respect.
    I’ll order up another pulley just to be safe though.
