ISE 10 not finishing cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE 10 not finishing cycle
  • #101750
    flannel
    My 9 year old ISE 10 stops at 4 minutes from the then end on the Everday-wash cycle.
    I’ve drained it with the tube (not much came out) and checked the drain pump is clear.
    The stop/start and open door buttons don’t work. Turning it off and on it changes it to 12 minutes and it starts to do something – at this point, pressing the stop button ends the cycle and I manually open the door. For reference, the spin & drain cycle is 15 minutes.
    Can anybody suggest what might be wrong?
    #485918
    flannel
    The washing machine is an ISE 10 W256W (ASKO WM70.1)
    #485919
    Check for something stuck in the drain outlets, 5p pieces are a favourite for that and thy act (or can) like a flap valve on the pump outlet spigot.
