Re: ISE 10 rinse hold
So far as I know Mark there isn’t a rinse/hold on the 10. The only way there may be one is if it’s automatic on the delicate cycle, but I have one here so I will test it over the next couple of days for you and give a definitive answer.
TBH we’ve been asked about rinse/hold twice in two years and as you likely know, it often produces more hassle than the damn thing is worth.
No spin will produce the same result with marginally greater creasing pretty much although in all honesty most people would likely struggle to tell the difference between rinse/hold and simply no spin.
