It is in the instruction book, did you net even get one of those? Its simple, pull off the short loop hose at the top of the back panel from the connector nearest the side panel, leave that hose dangling and fit the supplied extension hose to the connector where the other hose had just been.
eastlmark wrote:It is in the instruction book, did you net even get one of those? Its simple, pull off the short loop hose at the top of the back panel from the connector nearest the side panel, leave that hose dangling and fit the supplied extension hose to the connector where the other hose had just been.
Yes c/x got book but has probably connected wrong hose?
At the time c/x was using the draw to collect now wants to use the drain hose.
