ISE 10 vented dryer model DV06
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ISE 10 vented dryer model DV06
  • #86333
    Rograbbit
    Hi folks, just been called to ISE 10 vented dryer with broken belt. Never done one of these, is access from front? Any help appreciated. Belt number 7ph 1970. part number? on belt 8065710. Thanks in advance.
    #430829
    aqualectric
    Re: ISE 10 vented dryer model DV06
    All done from the back and quite an easy job. You can use (I have) a 1975 Zanussi drier belt, cheap and readily available as Connect BLT7699 or Qualtex POL54. The shaft has a nut holding it through the bearing – release that first; the rest think Zanussi drier method.
    HTH,
    Steve.
    #430830
    Rograbbit
    Thank you very much Steve. Think I have a zanussi 1975. At least I know the right way to go in now. Cheers.
