ISE 1406 – how to get coins out of the drum….
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE 1406 – how to get coins out of the drum….
  • #58634
    dachwilson
    We noticed a 50p coin slip down between the inner and outer drum casing during a wash. Its not appeared in the drain plug and dosnt appear to be making much sound during wash cycles.
    We’ve tried to follow the instructions to remove the agitators by using a screw driver – but there dosnt appear to be anything in the centre hole of the agitator for the screwdriver to grip.
    Could you let me know if there is any other way of getting into the drum to look for this coin , or if there is a trick to removing the agitators that we might not know about?
    David
    #335172
    Not really any trick to it other than catching the screw head, with the lifter off you should be able to fish out the coin.
    dachwilson
    Re: ISE 1406 – how to get coins out of the drum….
    Thanks for that. Have had my head right inside the drum looking with a torch, not a pretty sight from the back!, there are definately no screws though just a lot of scratches from the screwdriver.
    #335174
    Martin114
    Put screwdriver down centre hole in paddle the apply sideways pressure while pulling paddle forwards
    #335175
    dachwilson
    Thanks – thats worked now ! No sign of the 50p though 🙁
