ISE 1606W spin cycle not working
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE 1606W spin cycle not working
  • #93202
    ojjoseph
    I am hoping that fellow forum members can assist me in resolving an issue with an ISE10 washing machine model 1606W.
    The machine washes and drains fine, however, when it gets to the spin cycle or stage, the drum rotation gradually begins to pick up speed but after about 30 seconds into the spin it stops rotating and never gets to the 800 or 1600 revolutions per minute.
    The display that counts down the minutes to completion also goes off. Consequently the clothes are not spun.
    Thank you
    Nelson
    #453506
    Re: ISE 1606W spin cycle not working
    When you say ‘the display goes off’ does it go completely blank or are you left with three dashes in the display?
    What happens if you try the machine completely empty, will it reach full spin speed then?
    #453507
    ojjoseph
    The display goes completely blank. No dashes, letters or numbers
    I ran a test by staring a wash cycle with no laundry in the machine.
    Allowed it to collect some water.
    Stopped it when it collected a bit of water, then put it on the spin cycle to see if it would spin. I tried it at 800 and separately at 1600 speed but on both occasions the same thing happened.
    #453508
    Very odd and not something I have ever witnessed.
    It would point to either a motor or main pcb problem TBH. 🙁
    #453509
    ojjoseph
    Thanks iadom,
    If it is any of the 2 possible causes you suggest, are they expensive parts to replace?
    Nelson
    #453510
    Sadly very expensive, would advise inspection by an engineer with some experience of these machines rather than just changing parts.
    #453511
    ojjoseph
    OK thanks. I will contact a local engineer.
    Regards
