ise 2-2 fault e21 Home › Forums › Manufacturer/WP/Insurer Specific Forums › ISE Trade Support Forum › ise 2-2 fault e21 This topic has 4 replies, 2 voices, and was last updated 14 years, 7 months ago by petalpop. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts August 30, 2011 at 1:12 pm #64755 petalpopParticipant been emailed a call to repair anyone had e21 before as fault codes don`t go that high cheers August 30, 2011 at 1:38 pm #357973 kwattKeymaster Re: ise 2-2 fault e21 None of the ISE2’s had a digital display. 😕 Is it an AW23? K. August 30, 2011 at 8:28 pm #357974 petalpopParticipant Re: ise 2-2 fault e21 oops sorry yes Its an aw23 they purchased it with only the 2 year guarantee Thats what threw me August 30, 2011 at 9:17 pm #357975 kwattKeymaster Re: ise 2-2 fault e21 E21 Motor blocked: voltage is fed to the motor but there is no signal from the rate generator The E21 error code is displayed and the wash programme is terminated. – Faulty motor (rate generator, thermal switch or winding) – Motor connection block removed – Thermal switch open due to motor overheating K. August 31, 2011 at 4:56 pm #357976 petalpopParticipant Re: ise 2-2 fault e21 ok cheers so unless dodgy wire to motor it will need a new motor Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
