- This topic has 7 replies, 2 voices, and was last updated 15 years, 8 months ago by
robbra.
July 19, 2010 at 4:33 pm #55935
robbra
ParticipantHi,
got one that goes straight into spin. Presumably it’s the pcb like all the others.
Am I correct?
Rob
Ser no. 00615851000350130045
Two pcb listed on Whitegoods parts Which one?July 19, 2010 at 10:06 pm #325671iadom
ModeratorRe: ISE 2
Moved you to trade spares. 😉
Are you an ISE agent Rob, if so I will move this post to the ISE forum.
THIS is the one you need.
July 20, 2010 at 6:44 am #325672robbra
ParticipantRe: ISE 2
Thanks Jim,
Thought that was the one.
Yes I’m an agent but have never had authorisation for the ISE forum despite several requests.
RobJuly 20, 2010 at 9:56 am #325673iadom
ModeratorRe: ISE 2
Moved to correct forum.
Can someone ensure that Rob has access to the ISE forums please. 8)
July 20, 2010 at 10:44 am #325674iadom
ModeratorRe: ISE 2
Hope I haven’t stood on anyones toes or broken anything but I think I have been able to give you access to this forum Rob. 🙂
July 23, 2010 at 12:39 pm #325675robbra
Thanks Jim,
Had the new board and went fit it and nothing except the start light on. No fill, motor nothing but the door locks. The new board is beige but the old one was green, does this have any bearing on it?
No fault showing with either the old or new boards. The connections are flimsy but I crimped them up.
Not sure what to do next, could it be a faulty board?
Any help most welcome.
RobJuly 23, 2010 at 3:03 pm #325676iadom
ModeratorRe: ISE 2
Hmm, not something I have encountered, the board has been changed but the last one I did was a one for one swap.
There are a couple of the connections that will fit on the wrong place on the PCB, got caught out once with that and the result was exactly as you describe. 😳
I have changed four or five, all for spin on wash up to now.
PS. There doesn’t appear to be a wiring diagram in the manual but there is a fault test routine.
I do have a copy of a Vestel wiring diagram, its supposed to cover the ISE 2, I will send you a copy just in case.
July 23, 2010 at 3:46 pm #325677robbra
I’ve downloaded the tech manual and your diagram so will go armed and can trace the wiring from that PCB photo. Very poor connections on the board so it may be something there. Thanks again.
Rob -
