ise 2 fault?
  • #34069
    kladave
    just back from putting in an ise2 but when i tested it on rinse the motor appeared to start to quick on every wash direction,but not as aggresive as spin on wash.i had kept these machines in a storage unit without heating and i’m just wondering if the machine had some build up of moisture in it when i installed it into a hot kitchen.
    any suggestions please
    dave
    #241107
    bazza500
    Re: ise 2 fault?
    I`ve noticed this as well but don`t think it is a fault. I wondered if it was be more noticable because it was empty.
    I would say it is slightly more aggressive than other machines but nothing like having no tacho feedback.
    #241108
    Sean’s the man for this one as he’s been testing them to death and then resurrecting the things from the dead. He’s a bit of a ghoul really. 😆
    He should be able to say if it’s normal or not for sure but I would guess it is just the tacho/PCB picking up the fact that the motor has actually started to move and then the control kicks in. Cant’ b sure though, not tested it myself.
