ISE 2 Problems with doorlocks
Viewing 7 posts - 16 through 22 (of 22 total)
  • #266766
    Re: ISE 2 Problems with doorlocks
    Stick a Hotpoint one in and don’t tell anybody.
    Now he tells me, I assume you mean a WMA/WF type interlock, didn’t know they were interchangable. 😳
    Yerst. HP62103. £1.79 from M/pt.
    :rolls: I’ve got at least 6 in stock, could have cracked today. Never mind, worth knowing for the future. :tup:
    Can confirm that Hotpoint WMA interlock worked a treat. I used a Qualex INT51, the connections are at the bottom of the switch but there is enough length in the cables to allow it to fit.
    bazza500
    I fitted a gen Hotpoint one to an ISE2 today and when I closed the door I couldn`t get it open again. The hook on the door is just slightly bigger than the hole in the interlock. Ended up having to strip the front off and cutting through the interlock to get it open.
    All while the customer stood watching 😳
    No-one else came across this?
    #266772
    Only tried that one and it wasn’t a gen Hotpoint one.
