ise 5-2
  • #74383
    alfie
    My first call to one of these. It has an E10 fault.
    Fills, empties but no wash or spin. Suspect motor problem.
    I cant find A manual for this machine with digital display and induction motor. Is there one?
    Read some posts re inverter cards. Is this the module fitted in base at front? could this be the cause of my problem?
    Thanks in advance
    #391301
    Re: ise 5-2
    Yes, motor or inverter card will be the likely cause or, the wiring in between.
    alfie
    Re: ise 5-2
    cant find A repair manual for this machine with digital display and induction motor. Is there one?
    #391303
    Re: ise 5-2
    Yup, in the stickies at the top of this forum.
    alfie
    Re: ise 5-2
    This is the only one I can find.
    Servicing & diagnostics guide Version 1.0 – December 2008.
    Not applicable to my machine . Is there another version?
    #391305
    alfie
    Re: ise 5-2
    Cant see a E10 fault of inverter card,induction motor in that manual
    #391307
    Re: ise 5-2
    Possibly not but it has been discussed at length many times. I can’t even recall if it was in the original manual TBH.
    Re: ise 5-2
    AFAIK E10 is not a recognised error code. E08 is motor fault.
    Although there is THIS
    #391309
    aqualectric
    Re: ise 5-2
    Had a couple of E10’s….
    Wiring, solder joint on inverter card, faulty inverter card ….in that order.
    Steve.
