Re: ISE 5-2 bearing change?
Not that bad a job, good practice as I have another to do on Friday plus a CI555WH bearing change as well.
I intended to remove the motor from the drum rear to make it easier to handle but it was so tight it felt as though either the motor castings or the mounting lugs would give way or be seriously stressed so I managed with the motor attached.
They are huge stonking bearings on these, a pity the seal isn’t as good although the replacement main bearing is now a sealed one.
It looks as though a motor change is a tub out job on these as well. 🙁
