Re: ISE 5/2 F08.
Pretty sure the motor is, or it was four months ago, a pig to fit though and the last one I did turned out to be the NLA inverter board after all. 😥
You are supposed to remove the drum to change but the first one I did by lying it on one side. Found it easier with the next couple to carefully lie it on it’s front with plenty of padding on the floor, still a bugger to change but better than having to take the drum out. Hardest part is getting the new motor back onto the lugs.
