ISE 5 not going into spin on a full wash – 30min wash OK?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE 5 not going into spin on a full wash – 30min wash OK?
Viewing 1 post (of 1 total)
  • #86348
    mzungu
    Model ISE 5 Basic Type No. NN1647CV4
    Machine will do a short 30 min cycle, fills, empties, spins no problem.
    On longer cycles machine washes, rinses, empties OK but sits with pump running and does not enter spin. Also water does not get heated.
    Checked pressure chamber bottle is clean and clear.
    Checked pressure switch with a multimeter and blowing down the tube, only one click heard when I blow and one click when I stop.
    Multimeter check on pressure switch:
    11-14 Normally open, apply pressure, contacts close OK
    11-12 Normally closed, apply pressure, contacts open OK
    11-16 Always open circuit
    Are the 11-16 contacts for a high level fill which the short wash doesn’t use or am I not blowing hard enough?
    Heater element is open circuit.
    I’ve looked in the spare parts section is the CI555WH the same model as the ISE 5? The machine looks like it’s made by Beko.
    Can someone confirm what the part numbers should be for:
    Heater element
    Pressure switch
    Door seal
