Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ise 5 washing machine
- This topic has 3 replies, 2 voices, and was last updated 11 years, 5 months ago by
jmn450.
October 25, 2014 at 10:31 pm #82778
jmn450
ParticipantMy machine, purchased 2007, has developed a fault. It cuts out and trips the electric when the machine is spinning towards the end of the wash cycle. It appears to behave normally until that point. If I reset the electric and allow the machine to carry on, it does so for a couple of minutes and then cuts out again. An engineer has checked the machine’s internal wiring and eliminated any potential problems. I have tried plugging it in to a different socket and the same fault occurs. The machine has also been unreliable at coming on when using the time delay option. I eventually tried the reset procedure and can’t follow this through. I can get the machine to start draining, but can’t abort it, and there seems to be some haphazardness with the lights on the control panel, flashing, not coming on when expected etc. Any suggestions?
October 26, 2014 at 7:50 am #420799iadom
ModeratorRe: Ise 5 washing machine
Was the engineer who checked it an authorised ISE agent, did he megger test all components?
I would be looking at the motor, especially the carbon brushes. 😉
Sent from my iPad using Tapatalk HDOctober 30, 2014 at 10:36 am #420800jmn450
ParticipantRe: Ise 5 washing machine
Hello
Thank you for your swift reply. My engineer had tested all components and has now changed the brushes, which were definitely due for it. However, the problem remains.
I set the machine to come on during the night using the timer delay. All looked set to go, but when I came down in the morning, no lights or action. I pressed the start button and it started to drain. I let that carry on (although no water in it and set to 60 degree wash). Then I pressed start again and it went into action, appearing normal except that the spin light rather than the wash light was on. It carried on washing happily, all ok other than giving off a slight electrical smell once it was well in to the cycle. As it got towards the end of the wash cycle, as the spinning action got going, it tripped the electric circuit. The laundry appears to be washed, but is wetter than it should be though not dripping.
Any ideas, advice much appreciated.
Julia
October 31, 2014 at 12:14 pm #420801iadom
Sadly that sounds very much like a failing motor.
