ise 555 intermittent no spin
Home Forums Manufacturer/WP/Insurer Specific Forums ISE Trade Support Forum ise 555 intermittent no spin
  • #39082
    delta01
    seems to be emptying ok. cust says it spins a little then stops with start/pause light flashing i think could detect slight noise from brushes, am going back on mon. as i was only collecting the rent when they informed me of the problem any hints appreciated
    #261234
    Martin114
    Re: ise 555 intermittent no spin
    Check for earth leakage on armature.
    #261235
    aqualectric
    Out of balance load? One or two heavy items will sometimes cause a no spin fault. Had one today!!!!
    Steve.
    #261236
    Assuming this is an ISE machine then this forum is the best place for tech discussions etc, not the general trade forums. 😉
    Del
    As Steve says out of balance, or partially blocked filter would be the first things to check.
    Sean
    #261238
    delta01
    which forum ? iadom
    #261239
    I moved the thread from the Trade Technical forum where you originally posted it into the dedicated ISE Support forum. 🙂
    delta01
    thanks iadom sorry about the confusion, i could not find it b4 had to do a search
