ISE 555 was ok , So i thought!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE 555 was ok , So i thought!
  • #85277
    ceedy
    Just happened to be passing by ( I try to avoid that area 😉 )
    And thought sounds a bit loud .. asked HER!!! and told yeah been like that for a while , was going to mentioned it :rolls: .
    Seems the bearings are a tad slack .. 😯 ..
    Not been on the forum since I cured the leaky drum many months ago ..
    ta
    Chris
    PS just bin in the shop .. 😀 seems the only place to find them
    #428251
    ceedy
    Re: ISE 555 was ok , So i thought!
    Just a quickie …
    So I don’t strain myself too much 😆
    Largish torx holding on the Spider on the main shaftat the back ,
    is it normal right hand thread ?? .. Cos it a bit tight! 😳
    C
    #428252
    Yes, give it a couple of hard clouts with a big hammer to break the loctite seal taking care not to damage it.
    PS, That’s the drum pulley, the ‘spider’ is inside. 😉
    #428253
    ceedy
    yup my bad,,, Did get it off but didn’t half need a good hiding to get the shaft out.( did use another 8mm to take the pounding)
    the Outer bearing has disintegrated, misshapen balls ooer!
    the cage has disappeared completely 😯 ,
    so a bit of a mess all round , Spider seal surface is ok and smooth , just waiting for the bearings.
    Oh !! and the slime inside .. 😉
    C
    #428254
    You should always fit a new drum seal.
    #428255
    ceedy
    All done, finished quiet and no leaks ..
    Rear bearing disintegrated, couple of nearly square balls , and the cage as gone into a pile of swarf on the ground .?
    byzz til next disaster .. 😀
    C.
