Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › ISE AW23 Shock Absorbers
- This topic has 7 replies, 3 voices, and was last updated 12 years, 1 month ago by
climber1.
February 23, 2014 at 10:24 am #79671
climber1
ParticipantHi,
I’m struggling to find shock absorbers for an ISE AW23.
Can anyone point me in the right direction or tell me what manufacturers components the AW23 uses?
Many Thanks 😀
February 23, 2014 at 10:33 am #410184kwatt
KeymasterRe: ISE AW23 Shock Absorbers
We’ve never been asked for them out of warranty apparently.
A quick mail to Dave on spares@ukwhitegoods.co.uk will get them listed in the store for you. From memory they are a stock item.
February 23, 2014 at 10:42 am #410185iadom
ModeratorRe: ISE AW23 Shock Absorbers
I have changed a few, only the left hand side ones (from the front) though. Usually due to a leak from the dispenser hose. The single side suspension unit is different to the double side ones.
Sent from my iPad using Tapatalk HDFebruary 23, 2014 at 12:37 pm #410186climber1
ParticipantRe: ISE AW23 Shock Absorbers
Thanks for your help guys.
It is indeed the single side LHS shock absorber – previous leak from dispenser hose – drum was rubbing on hose due to weak shock absorber.
I’ve checked the part number on the unit:
8029504 LHS shock absorber
8037285 Suspension shaftUnfortunately, looks like they’re not in stock in your store – delivery 15 to 25 days.
February 23, 2014 at 12:53 pm #410187iadom
It’s actually caused by the small spring, top rear of drum being too short. You should try and stretch this spring a little to prevent drum rubbing against the hose. 😉
If the shock absorber was weak the drum would sit lower and not come into contact with the hose at all.
February 23, 2014 at 1:24 pm #410188climber1
Thanks for the tip re the spring length.
The whole drum is sitting to the left and slightly to the rear of machine and one of the lugs on the drum is rubbing on the filler hose.
Shock absorber insert now extremely worn and spring weak/noisy.
February 23, 2014 at 1:29 pm #410189iadom
It’s a chicken and egg situation, the short spring causes the drum to rub on the hose, the resultant leak damages the suspension.
February 23, 2014 at 4:31 pm #410190climber1
Yes, chicken/egg scenario – and a design flaw. A bit annoying when these things occur.
And the parts are “Amica” – can I gather from this that the AW23 is a re-badged Amica machine?
