Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › ISE AW23 Woes…..
- This topic has 8 replies, 3 voices, and was last updated 13 years ago by
Threecoos.
March 12, 2013 at 9:41 pm #74534
Threecoos
ParticipantHello all,
Our ISE AW23 is in it’s third year (under warranty still) and we’ve had the engineer out on a few occasions to repair different faults (new drum and door seal, new PCB and front panel, balance problems).Yet again though, it’s suffering from taking a good bit longer to complete a wash than the time shown on the display (a 50 minute wash may take over an hour to complete).
Also, it seems to get stuck on the last minute of the cycle and can quite happily keep on washing/spinning/draining until you switch it off!
What is wrong with this thing?
Yes, I know that I can call out an engineer to fix it but what is the underlying cause of this repetitive behaviour?Thanks for reading this novelette and also for any advice given.
Andy
March 12, 2013 at 9:54 pm #391936Martin
ParticipantRe: ISE AW23 Woes…..
I take it you have checked the drain filter?
March 12, 2013 at 9:57 pm #391937Threecoos
Regularly, why would that affect the time taken to complete a cycle though?
March 12, 2013 at 9:59 pm #391938kwatt
KeymasterRe: ISE AW23 Woes…..
All the programs are dynamic and the times will change all the time depending on the conditions such as water pressure, water temperature, load size, absorbency of the laundry….
In other words, it’s a guide like almost all these times are, not cast in stone.
March 13, 2013 at 5:56 am #391939Threecoos
So, if the water isn’t heating up – would this prolong the length of the wash cycle?
March 13, 2013 at 8:35 am #391940kwatt
No, the machine would halt and display an error code.
If the machine completes the cycle then it’s fine, the time taken will vary and that is not a fault at all, it’s perfectly correct that it should do that.
The other issue sounds like something in it (filter most likely) or the machine trying to sort an imbalanced load out.
March 14, 2013 at 9:55 pm #391941Threecoos
Carrying on in the same vein, the machine is now well over two hours into a simple 30/40 mix program 😡
It’s sitting at one minute left on the display and will happily stay on that cycle all night unless I switch it off.
Surely to grief there’s something amiss?
March 14, 2013 at 11:18 pm #391942kwatt
Yes.
But if something is stuck in the pump and it can’t drain correctly it would explain that nicely. It is the most likely cause.
March 17, 2013 at 12:29 pm #391943Threecoos
Okay, I’ve removed the pump access plug, I can see the impeller and there’s nothing in there but water.
I’m now running a maintenance wash (95º cotton program) and the water is not heating up, why am I not seeing an error code on the display?
Looks like it’s engineer call out time……………again 😡
