ISE CD60W tumble dryer drum shaft and bearing
Home Forums Public Support Forums Spare Parts Help ISE CD60W tumble dryer drum shaft and bearing
  • #96780
    Balt
    Hi, my ISE tumble dryer (model CD60W) has started making a loud scraping noise. The drum feels loose, and I am 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure it is a worn drum shaft and/or bearing. I know the company went bust and so parts are hard to come by. Can anyone advise where I can get hold of a drum shaft kit for this machine, or advise if there is any other make / model that would work? Many thanks
    #464786
    Specialist01269
    Hi: All parts available are listed in the UK Whitegoods shop.
    #464787
    Balt
    Hi, thanks. I couldn’t find this item listed, but I don’t know if that is because I am using the wrong search term or whether there is a generic drum shaft/bearing that would fit (I recall that ISE appliances were designed from easily replaceable / repairable components). Any help would be much appreciated.
    #464788
    Specialist01269
    Hi: Just go to the shop and put ISE CD60W into the search bàr, all available parts are listed.
