ISE condensor dryer cd601w back panel replacement
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ISE condensor dryer cd601w back panel replacement
  • #90060
    paulg2906
    hi wonder if anyone can offer me any advice on replacing the rear panel on a ise cd601w the bearing has worn through the rear panel , what i really need to know is can i just remove the rear panel or do i have to remove the drum from the front ? hoping some one can offer me advise on this as the customer has sourced the rear panel from ukwg
    thanks in advance
    #443422
    EFS
    Re: ISE condensor dryer cd601w back panel replacement
    Lay on front and remove all screws paying attention to which type of screw goes where.
    Then lifts off.
    One screw holds a plastic clip which secures a hose to the back plate
    Not difficult.
    Looks like you will need the bearing as well
    Steve
    #443423
    paulg2906
    Thanks for that just wanted to be sure thanks again
