Trying to find a heater that will match the bosch 265961. Been having a rummage in the van and found the ISE heater is the right length, wattage, has a thermistor hole and has the correct style seal on it.
The heater gasket is the crucial thing to match as Martin experienced. The bosch element has the same gasket as the ISE heater so i’m sure it would be safe.
The bosch machine has a flat surface around the heater aperture i assume the ISE is the same.
