Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › ISE help please!!!
- This topic has 10 replies, 4 voices, and was last updated 16 years, 11 months ago by
clatsopduck.
May 1, 2009 at 1:16 pm #45383
clatsopduck
ParticipantI have a load of washing trapped inside the machine at the end of a cycle because I can’t get the door to open! I have tried waiting, I have tried turning it completely off. I have tried running an additional spin cycle. I have emptied the filter in case there was water trapped in there (there wasn’t). I have no further ideas of what I can do!!!
I can’t find my users manual, so I can’t look to see if there is some super obvious solution. I can’t open the door to look at the model number and I don’t know where my documentation is. I’m sure I’ll find it, but it may take a few hours (which I don’t really have today.) I know I sound incredibly unorganised, but I have 5 kids on my own and my filing cabinet is broken!
Please, does anyone have an idea what’s going on? The machine was new in February!
As another possibly unrelated bit of information, I have noticed the past few loads that the “end” light stays on too long and when I start the next load (different setting) it still shows the settings from the previous load. I don’t know if this has anything to do with the door not opening, but if it doesn’t think the load has ended completely then it might explain why it won’t unlock.
May 1, 2009 at 1:21 pm #285506timdowning
ParticipantRe: ISE help please!!!
Have you taken the plug of the machine out of the socket rather than just switching the socket off?
Leave it unplugged and try the door again after a few minutes.
Make sure the water level isn’t above the glass when you try.
As you have checked the filter I would imagine that all the water is out of the machine but better to be safe than sorry.May 1, 2009 at 1:32 pm #285507clatsopduck
ParticipantThanks. I will try that after the cycle that my son started (grrr) finishes! lol
There was definitely no water in it. (Until my son started the cycle!)
May 1, 2009 at 1:43 pm #285508timdowning
Little fingers. 🙂
May 1, 2009 at 2:36 pm #285509clatsopduck
Participant12yo fingers, I’m afraid – old enough to think that his mucking about might actually help!!! lol.
Have tried the unplugging it and replugging it and it still won’t open. 🙁
May 1, 2009 at 2:49 pm #285510iadom
ModeratorRe: ISE help please!!!
Is the machine an ISE 5 with a digital display with yellow numbers & letters?
I can send you a PDF of the manual if you wish. I assume you have already contacted your local agent.
May 1, 2009 at 2:51 pm #285511timdowning
The fact that its going through the cycle and its not flashing any error codes I would say its the door handle or door lock at fault.
Leave it unplugged for a while the door lock may gradually release itself.
Other than a firm tap on the door handle, careful now, a call to your retailer will be in order.
May 1, 2009 at 2:57 pm #285512clatsopduck
ParticipantPretty sure it’s an ISE 5 – it certainly has a digital display with yellow numbers and letters. No error codes.
A PDF of the manual would be great!I have not yet contacted a local agent though as I bought it through White Goods, I don’t know who my local agent might be. (Or how to contact someone about repair.)
I’ll try the leaving it unplugged for longer and the tap on the door handle (I’m probably more worried about breaking it than most, lol.)
Thanks for your help!
May 1, 2009 at 3:01 pm #285513iadom
The phone number for ISE HQ is 0845 226 1268.
Manual already sent to you. A bank holiday weekend coming up as well. 😥
May 1, 2009 at 4:09 pm #285514clatsopduck
ParticipantThanks, Jim.
I sure hope that something manages to resolve the problem over the weekend as I’ve not managed to get through to anyone today! 🙁Thanks for all your help!
May 1, 2009 at 5:06 pm #285515traceukw1
KeymasterRe: ISE help please!!!
Sent you a PM. 😉
Tracey
