Gotta go and replace the internal fan on a T25wc dryer. Never done one before. Anyone got any advice on accessing the fan. doesn’t seem as straightforward as the front access on the CD60.
Only done a fan change once. Not a 5 minute job, I’m sure I had to cut the old fan off due to it being so tight. I also had issues with getting it to be water tight once back together. If you can’t get the housing gaskets I would be patient and let some silicone set before testing with a wet load.
