ISE w1607w
  • #99614
    El Kabong
    Odd problem, a couple of times the machine has just got stuck in the middle of a programme. No fault codes, just stopped. Took bit of fiddling to get it restarted. Last night it got stuck on the last spin cycle, did not finish until I pressed the stop/go button (NOT power). No fault codes, otherwise appears to wash OK.
    Any thoughts anyone? Sticking sensor of some kind? Rather puzzling!
    Thanks.
    #477097
    How long was it on the spin cycle, did the display stick or keep counting down? Unfortunately if it sticks in the last full spin cycle but is draining and spinning perfectly that points to a fault in the main control panel.:(
    #477098
    El Kabong
    Thanks for your reply, it seemed to be draining and spinning OK, the display was stuck at 1 minute. So I suppose a main panel is the most likely, unless there is anything else I can try?
    #477099
    Sometimes slight leakage to earth, especially from the heating element can cause unusual problems such as sticking at 1 minute on lots of different makes of washers but it is not something I have ever encountered on ISE machines.
