ISE W256W DISPENSER
  • #92720
    DASLTD
    Hello
    We have been asked to order and change a dispenser unit on an ISE W256W
    never done one before, can anyone advise if this is a simple job,
    Many thanks
    Simon
    #451979
    Re: ISE W256W DISPENSER
    yes simples.
    lid off, control panel off ( retaining clips just need tweaking from above, then prise off from the bottom edge.) no need to disconnect the wires. This exposes one screw at the front of the dispenser, the other 2 are at the top into the side panel.
    cut off the fill hose clips at the rear (remember which fill hose goes to where, there is usually one spare so don’t get confused as its a blank.) and cut off the breather clip on the grey pipe.
    Leave the dispenser closed and you can now remove it from the casing enough to cut off the dispenser hose clip. At this stage- leave the trim front on the old dispenser.
    re fit the dispenser hose first – you will need a new set of clips as you don’t get them with the dispenser. Then locate the dispenser into the front panel. there is a hook in the front which goes behind the pivot for the swing out part and a tab that locates in a slot in the dispenser at the narrow end. fit the screws and check it swings in and out without fouling. Re fit the hoses using new clips or cable ties.
    To remove the trim panel from the old one, simply prise it towards the narrow end using the blade of a small screwdriver from the inside edge. it will pop off and can be easily slid onto the new one in reverse- no glue required!.
