ISE Washing m/c pauses every wash
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ISE Washing m/c pauses every wash
  • #68379
    andyman2
    This is the original ISE washing machine and is now out of guarantee. As per title the machine goes into PAUSE every time we use it (standard 40 degree, quick wash). Pressing the Start button always kicks it off again. Typically it fills for a split second before carrying on to completion. This happens about half way through the wash. I did by mistake do a non quick wash over the weekend and this didn’t pause, but my other half thinks she has had problems with this wash too. Just wondering if any one has any ideas?
    #370826
    Re: ISE Washing m/c pauses every wash
    andyman2 wrote:This is the original ISE washing machine and is now out of guarantee.
    Could you please tell us the model number of your machine anyway? 😀
    #370827
    bryan-206
    Does it heat the water?
    Life’s a bitch ain’t it!
    #370828
    andyman2
    I’ll check model tonight and kick off a wash to see if it heats – thanks for responses!
    #370829
    andyman2
    Model number is CI 555 WH
    The problem seems to be consistent on the “quick” 40 degree cotton wash
    Fills/heats/washes (about 45 mins?)
    Fills and then stops
    Press start (sometimes there is a tiny extra fill, less than a second) and then it carries on. I dont believe it has heated the water on the second fill.
    IS there a weight sensor? I guess the washing weighs a lot more on the second fill?
    #370830
    andyman2
    Just noticed your signature Martin, off to see The Best Exotic Marigold Hotel tonight!
    #370831
    andyman2 wrote:I dont believe it has heated the water on the second fill.
    Yes I think that it may be that the heating element no longer works. 🙁
    Enjoy the movie by the way, I did! 😀
    #370832
    andyman2
    The machine does wash OK, the heater does work, I just think it hadn’t heated up at the point the machine stopped?
    #370833
    You really need to run the diagnostics, or get your local ISE agent to do so. It only heats on the first fill, it does not heat on the subsequent, cold rinses.
    #370834
    bigchrisrogers
    Did you solve this? I have a very similar problem.
    #370835
    bigchrisrogers wrote:Did you solve this? I have a very similar problem.
    But your machine is a Hotpoint and not an ISE therefore bears no similarity. 😐
