ISE10 1607W
  • #76464
    Alanj
    Hi Guys, called to above machine this morning. It has no selector lights lit, display is backlit but no numbers showing and it is continually filling and emptying at same time. On/off switch works, and if machine switched on with door open it still pumps out but does not take in water. Any ideas?
    Alan
    #398427
    Re: ISE10 1607W
    Sounds like it’s confused, possibly a pressure sensor error of some kind.
    Did you do a reset?
    TOTAL RESET
    Turn off power using the power button
    WAIT FOR AT LEAST 5 SECONDS TO ALLOW THE MEMORY TO CLEAR
    Press and hold the door open button and keep it pressed
    Turn the power back on using the power switch button
    Release the door open button once it lights up
    Machine should now be reset to factory default settings and the test program can be run.
    Lawrence
    Re: ISE10 1607W
    does it have a tumble dryer on top ?
    #398429
    Alanj
    Re: ISE10 1607W
    Hi Lawrence, no tumble dryer on top but is a 6lb tumble dryer on shelf above it.
    On closer inspection found that thermistor connection on board was blown and thermistor itself was scorched.
    What were you thinking?
    Alan
    #398430
    Lawrence
    Re: ISE10 1607W
    I have had condensation creep from a tumble dryer above ,it caused a short on the block on the board
