Ise10 door lock
  • #95960
    deltra
    hi, machine works great wash etc,but when it ends,door doesn’t unlock! Can open it by emergency pull, is it door lock faulty? If so can I still get parts?
    #461871
    https://shop.ukwhitegoods.co.uk/8061679-washing-machine-door-safety-interlock
    well this one lists ISE10 but not sure if there is more than one so ask
    deltra
    Seems a lot for a door lock. Thanks dave
    #461873
    wait till you see what espares are asking
    https://www.espares.co.uk/product/es1648694/8061679-door-lock-wm20
    Have you checked that the auto open has not been cancelled, or will it not even open using the button?
    deltra
    Won’t open using button jim
    #461876
    deltra
    Wow Espares…… never use them,now I know why
    #461877
    I don’t know but from what I can see of the door lock should be a solenoid operated unit. if yes you should measure the solenoid coil between terminal 2 and terminal 3 of the lock. if this is open circuit it likely the coil has failed. If yes to this then have had 2 or 3 bosch solenoid lock where the coil wire has snapped on the terminal and have managed to re solder
    can get tech if needed but there is more than one ISE10 model so need more info
    deltra
    I’ll get model thanks
