Hi Guys,
I made a little discovery today in all the tech info that may well be of use to you or your customers that may have skin issues greatly. What you can do is program the PCB so that the machine gives either 3 rinses (the way it comes for program speed) or up that to five rinses as standard.
This is Noddy so either you can do it of the customer can do it themselves as it’s so easy…
Machine powered off using the main on/off button.
Press and hold both the start and door open button.
Switch main on/off to “on”
After a few seconds the main program indicator (red ring) will flash.
Release start and door lock button.
Now three segments of the program indicator lights (around the start/stop/door) button will be lit.
Press the door lock button to make either three lights lit (three rinse option) or five lights lit (five rinse option). Once selected this becomes the new default value.
Press start/stop to exit.
Done.
HTH
