ISE10 F1 error
  • #58413
    biffa
    The machine keeps throwing an f1 error. It gets about 3/4 of the way through a wash, then stops and shows the F1 error. The drum is about a third full of water. I have to set it to drain to be able to open the door.
    Not sure why this is happening – the door appears to be fully closed, and the wash starts off happily enough, but won’t finish.
    Jon
    #334493
    Hi Jon,
    Is there a lot of foam in the machine as it is is possible that too much detergent is causing the error?
    It certainly sounds like that from the description.
    biffa
    Re: ISE10 F1 error
    That must be it
    I’ll have a word with the washerwoman 😉
    thanks
    Jon
